Building Rtems 4.5.0 beta 3
Thu Nov 16 13:52:41 UTC 2000
Stevens Brian wrote:
> I have been trying to build the rtems environment for the power pc card.
> I have build the toolset, yet when I try to build rtems i get the
> error:-
> Checking for executable suffix... configure: error: installation or
> configuration problem: compiler cannot create executables.
> However, as far as i can see the compiler built ok and is in my path as
> powerpc-rtems-gcc.
Can you do this?
main.c:
main() {}
powerpc-rtems-gcc main.c
This looks like the test that is failing.
FYI "bit_rtems powerpc" will build EVERY powerpc BSP.  Probably not
what you intended.
> Any ideas.
> Thank You
> Brian Stevens
> Tel.  +44 (0)1252 393959
> Fax. +44 (0)1252 395120
> The Information contained in this E-Mail and any subsequent correspondence
> is private and is intended solely for the intended recipient(s).
> For those other than the recipient any disclosure, copying, distribution,
> or any action taken or omitted to be taken in reliance on such information is
> prohibited and may be unlawful.
