BOOTP/DHCP
Eric Norum
eric.norum at usask.ca
Wed Nov 22 16:56:04 UTC 2000
Andrew Bythell wrote:
> Hello -
> The RTEMS User Manual claims support for "BOOTP/DHCP". I realize that
> the two protocols are quite similar, but while BOOTP works, DHCP does
> not. For my project, using BOOTP is not an option, as I am not allowed,
> nor do I want to have to add hardware addresses to the DHCP server.
> Am I correct in assuming that RTEMS has no DHCP client support? Does a
> DHCP client for RTEMS exist?
That is correct.
The BOOTP/DHCP code in RTEMS is there only to supply an RTEMS client
with its network parameters.
Eric Norum eric.norum at usask.ca
Department of Electrical Engineering Phone: (306) 966-5394
University of Saskatchewan FAX: (306) 966-5407
Saskatoon, Canada.
