Compiling problems
Vasudev Mulchandani
vasu at teil.soft.net
Tue Nov 28 03:50:31 UTC 2000
Hello Joel
Correct me if I am wrong. I have installed newlib version 1.8.2 and
gcc version being 2.95.2. I believe these are the latest versions.
Vasu
Joel Sherrill wrote:
> Vasudev Mulchandani wrote:
> > Hello !
> > I was trying to build rtems for pc586 target. I have installed
> > the cross compiler successfully. Now I run into the following
> > compilation problem.
> It looks like your tool version is too old. pthread.h was moved
> from RTEMS to newlib and your tools still expect it to be in
> RTEMS. Grab the RPMS or new patches.
> > Making all in src
> > make[5]: Entering directory
> > `/home/rtems/i386bld/i386-rtems/c/pc586/exec/posix/s
> > rc'
> > /usr/local/bin/i386-rtems-gcc --pipe -B../../../../../../pc586/lib/
> > -specs bsp_s
> > pecs -qrtems -g -Wall -ansi -fasm -mcpu=i586 -c
> > -D__RTEMS_INSIDE__ -O4 -o
> > o-optimize/adasupp.o
> > ../../../../../../../rtems-4.5.0-beta3a/c/src/exec/posix/s
> > rc/adasupp.c
> > ../../../../../../../rtems-4.5.0-beta3a/c/src/exec/posix/src/adasupp.c:7:
> > pthrea
> > d.h: No such file or directory
> > make[5]: *** [o-optimize/adasupp.o] Error 1
> > make[5]: Leaving directory
> > `/home/rtems/i386bld/i386-rtems/c/pc586/exec/posix/sr
> > c'
> > make[4]: *** [all-recursive] Error 1
> > make[4]: Leaving directory
> > `/home/rtems/i386bld/i386-rtems/c/pc586/exec/posix'
> > make[3]: *** [all-recursive] Error 1
> > make[3]: Leaving directory `/home/rtems/i386bld/i386-rtems/c/pc586/exec'
> > make[2]: *** [all-recursive] Error 1
> > make[2]: Leaving directory `/home/rtems/i386bld/i386-rtems/c/pc586'
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory `/home/rtems/i386bld/i386-rtems/c'
> > make: *** [all-recursive] Error 1
> > Any help is greatly appreciated ..
> > TIA
> > Adios
> > vasu
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
| Vasudev Mulchandani : Senior Specialist, D & D |
| Networking & Communications Group |
| Company : Tata Elxsi Ltd., Bangalore |
| Phone : +91-80-8410222 Fax : +91-80-8410219 |
