MIPS questions
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Nov 29 16:39:26 UTC 2000
Ralf Corsepius wrote:
> Patrick Kelsey wrote:
> > Hello,
> > We use two mips variants - 64-bit orion processors such as the R4700 and
> > a 32-bit processor based on IDT's RC32300 (a 32-bit mips core with no fpu
> > and a mutt isa: mips2 + non-64-bit mips4 + a few special insns like mad,
> > msub, etc.). The orion processors are supported directly by the mips64orion
> > targets in the gnu tools and in RTEMS. To support the 32300-based processor
> > under RTEMS, we added minor patches to the mips64orion cpu-specific files in
> > the distribution. Originally we used a hacked version of the mips64orion
> > gnu tools, but we are moving to a separate gcc/binutils/newlib target that
> > we have created for the 32300 to circumvent some fundamental problems with
> > the former approach. So now we have two sets of tools built -
> > mips64orion-rtems-gcc et. al and mips32300-rtems-gcc et. al, with their
> > corresponding newlibs. The question is what is the best way to add support
> > for building RTEMS with the mips32300 toolset? The idea is that I would be
> > able to run either of these two commands:
> > bit_rtems mips64orion some_bsp
> > bit_rtems mips32300 some_other_bsp
> > and the configure process would select the appropriate toolset
> > (mips64orion-rtems-* or ) and the appropriate cpu-specific
> > subdirs. Currently, it seems that the name of the cpu-specifc subdir has to
> > be the same as the cpu name used to form the toolset prefix.
> Almost, things are a little more complicated.
:) I would like to end up with all mipsXXX-rtems targets being
variations on the same mips directories. How to accomplish this
is magic. :)
> > Perhaps there
> > should be separate ways to specify the cpu-specifc subdir name and the tool
> > prefix to accomodate situations like this.
> The subdirs' names are derived by configure scripts calling
> config.sub with the target's canonicalization tripple passed as
> argument to it.
> Manually invoking config.sub:
> sh ./config.sub mips32300-rtems
> mips643200-unknown-rtems
> I.e. config.sub thinks mips32300 is part of a mips643200 cpu family
> => RTEMS configuration would search for mips643200 subdirs
> internally.
config.sub is broken for this case. It is this code fragment:
mips3*-*)
basic_machine=`echo $basic_machine | sed -e
's/mips3/mips64/'`
mips3*)
's/mips3/mips64/'`-unknown
I saw this by setting -x and trying config.sub.
++ sed s/.*-/-/
+ os=-rtems
++ echo mips32300
++ sed -e s/mips3/mips64/ <=================
+ basic_machine=mips642300-unknown
+ [ x-rtems != x ]
+ vendor=unknown
++ echo mips642300-unknown
++ sed s/unknown/unknown/
+ echo mips642300-unknown-rtems
> > Or am I missing something?
> No, you're basically right, but there is one indirection more than
> you might have expected.
> Ralf
joel at OARcorp.com On-Line Applications Research
