Having a little trouble on an MCP750
Eric Valette
valette at crf.canon.fr
Wed Oct 4 17:07:20 UTC 2000
gregory.menke at gsfc.nasa.gov wrote:
> It actually worked once, the sample programs ran OK and we were
> proceeding with porting some software to RTEMS. Until I reconfigured
> RTEMS, after which all images I load fail at IP 5000 with an invalid
> instruction;
> 00005000 7F454C46 WORD $7F454C46
> Subsequently I've tried a bunch of different ./configure approaches;
> different directories, combinations of options, etc- and all give the
> same result. I've also tried reloading the rtems source and ppc cross
> compilers. My host os is Linux, if I target it instead, everything
> runs OK.
> On the target board, the binaries are loaded by tftp from a server.
> The logs show the connection and retrieval, cooroborated by the
> mcp750's console messages.
> I'm suspecting I'm doing something stupid, as the error is resolutely
> the same- but any hints are welcome as I'm at something of a loss.
You are probably using either the wrong binary (elf image instead of
Prep bootable image) or misconfiguread the network loader that must be
setup to be PREP compliant... See readme's...
__
/ ` Eric Valette - Canon CRF
/-- __ o _. Canon Development Europe Team Leader
(___, / (_(_(__ Rue de la touche lambert
35517 Cesson-Sevigne Cedex
FRANCE
Tel: +33 (0)2 99 87 68 91 Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr http://www.crf.canon.fr
