how can I catch an interrupt signal?
alberto capella alberto.capella at terra.es
Mon Oct 9 14:25:01 UTC 2000
Nick.SIMON at syntegra.bt.co.uk escribió:
> > -----Original Message-----
> > From: alberto capella [mailto:alberto.capella at terra.es]
> > Sent: 07 October 2000 12:49
> > To: rtems-users at oarcorp.com
> > Subject: how can I catch an interrupt signal?
> <snip>
> >   resul=rtems_interrupt_catch(sb16_isr,0x34,&old_isr_handler);
> How do you connect IRQ 5 with the 0x34 RTEMS vector you're attaching your
> ISR to?  And BTW which BSP are you using?
> -- Nick Simon
I'm using the pc386 BSP. My host computer is a i686 running Linux and the
target machine is a Pentium-MMX.
I ´d like to know what is the second parameter I have to pass to the
rtems_interrupt_catch directive if my SB is connected to the IRQ 5, so, what
is the value of the "rtems_vector_number  vector"  I have to use?
Not only I'd like to know this, but also  if I have to use some special
CFLAGS in my Makefile to do my program run correctly.
Alberto Capella.
