Heap and workspace memory.
Wed Oct 11 18:00:28 UTC 2000
William Halliburton wrote:
>         The FAQ gives a method of determining the workspace and heap with gdb. Is
> there an easy way from C?
There is not a function to do this at the moment.  It would be
relatively
simple to write this function based on the code in _Heap_Walk.  It could
easily calculate items like number free/used blocks, bytes,
minimum/max/avg
of used/free blocks.
The heap code is in c/src/exec/score/src.  _Heap_Walk already loops over
an entire heap. ALternatively, the _Heap_ALlocate routine also walks
over the heap looking for the first free block of sufficient size. It
might be a good starting point as well.
>         Thank you,
>         William
