Gnu debugger does not recognise the commands "setrpcmode sun" ...
Fri Oct 13 13:40:21 UTC 2000
Samuel Konnerth wrote:
> Hello again,
> thanks a lot, the --target=i386-RTEMS option works! Maybe it could also
> be corrected in the specs?
I would like to have this get turned on by default with XXX-rtems
targets.
Ths issue is that a host may not have the proper support to build the
rdbg host side source.  There need to be autoconf tests to check this.
Then it can be enabled by default.
Also we need to work to get all of the RTEMS gdb patches into the main
gdb
source base. :(
> Regards,
> Samuel
> antti.p.miettinen at nokia.com wrote:
> > > I tried now to build the gdb by using the patch (according to the rtems
> > > manual: bit_gdb i386).
> > > But the debugger that was build (the name of the exec file is
> > > i386-rtemsgdb and not i386-RTEMS-gdb) is still not recognising the
> > > setrpcmode, setdaemontype, target rtems.. commands.
> > > Do I have to build the debugger with a special option (-rtc or
> > > similar???).
> > Again, I dunno about the bit* scripts - I've just used the normal
> > configure scripts to configure the packages. You should be able to
> > configure gdb with --target=i386-RTEMS for using rdbg.
> ____________________________________________________
> Samuel Konnerth
> UMTS SW Development
> ALCATEL SEL AG
> Radio Communication Division
> Lorenzstr. 10
> D-70435 Stuttgart
> Tel:      +49-711-821 30360 (Alcanet: 2-503 30360)
> Telefax:  +49-711-821 42996
> GSM:      +49-171-4365156
> Email:    S.Konnerth at alcatel.de
> Email for life: 98.samuel.konnerth at aist.enst.fr
