fcntl() and required handlers Re: ss-20000929
Chris Johns
cjohns at cybertec.com.au
Tue Oct 17 06:58:24 UTC 2000
Joel Sherrill wrote:
> I have comments interspersed but this change is from
> Chris Johns and I would like him to comment as well. Here
> is the ChangeLog entry so it applies to other entries
> as well:
> revision 1.14
> date: 2000/08/11 20:04:27; author: joel; state: Exp; lines: +11 -5
> 2000-08-11 Chris Johns <ccj at acm.org>
> * libc/chmod.c: Return ENOTSUP if filesystem does not have
> handler.
> * libc/eval.c: Ditto.
> * libc/fcntl.c: Ditto.
> * libc/fsync.c: Ditto.
> * libc/ioctl.c: Ditto.
> * libc/ioman.c: Ditto.
> * libc/link.c: Ditto.
> * libc/memfile.c: Ditto.
> * libc/mknod.c: Ditto.
> * libc/symlink.c: Ditto.
> * libc/libio.h(rtems_filesystem_dev_major_t): New macro.
> * libc/libio.h(rtems_filesystem_dev_minor_t): New macro.
> Antti P Miettinen wrote:
> > I now know why fdopen fails but I'd like some guidance how to fix it.
> > Newlib fdopen does a fcntl with F_GETFL. RTEMS fcntl reacts with:
> > case F_GETFL: /* more flags (cloexec) */
> > ret = rtems_libio_to_fcntl_flags( iop->flags );
> > break;
> > and in 4.5.0 beta 3 a continues with
> > if ((ret >= 0) && iop->handlers->fcntl) {
> > int err = (*iop->handlers->fcntl)( cmd, iop );
> > if (err) {
> > errno = err;
> > ret = -1;
> > but in ss-20000929 with
> > if (ret >= 0) {
> > if (iop->handlers->fcntl_h) {
> > int err = (*iop->handlers->fcntl_h)( cmd, iop );
> > if (err) {
> > errno = err;
> > ret = -1;
> > else {
> > errno = ENOTSUP;
> > ret = -1;
> > resulting in failure.
> Which filesystem is this with?
> My first thought is that you are correct. This code was not
> 100% correct before either. I think this also applies to
> F_GETFD based on my reading of that man page. There is
> no reason to go to the filesystem/file specific handler
> for a get flags.
> The intention of this code is to let the handler get a shot
> at doing something when the generic code path worked. So
> for example, if you are setting flags, the filesystem handler
> gets a chance to react.
> > Couldn't fcntl just return at the switch/case F_GETFL? I suppose
> > devices might want to have their own fcntl_h to react to some things
> > in a special way but isn't for example F_GETFL always handled directly
> > and completely in fcntl()? Or should there always be at least a dummy
> > fcntl_h for fcntl() to be allowed to return ok?
> I think this argument is true for both F_GETFD and F_GETFL.
> The way the code is currently written, every filesystem has to provide
> at least a dummy fcntl_h handler. If it does not require one, then
> why should it be forced to return ENOTSUP.
Because I did not know better :-)
I made these changes as the miniIMFS broke as it referenced a null
pointer. Check `miniimfs_init.c' to see the table entries which are 0.
I plugged the hole but it looks like the code needs more work to be bad
correct.
Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
