rtems gdb patches
Wed Oct 18 14:36:03 UTC 2000
Matthew J Fletcher wrote:
> Hi,
> I have tried to patch both gdb4.18 and gdb5.02 with the rtems diffs
> (snapshots/gdb-xx-diff), but both fail on configure.in and makefile.in,
> the code files seem to have been patched just fine.
> I have used fresh virgin install (from the rtems site), of gdb both
> times, is this a known problem, or as anyone else had this problem.. ?
Could you provide some information on your host?  Are there .rej
"reject"
files?  What message is printed when you apply the patch?
Thanks.
> regards
> Matthew J Fletcher
> NPD Firmware
> Serck Controls Ltd, Rowley Drive, Coventry, CV3 4FH, UK
> Tel: 44 (0) 24 7630 5050   Fax: 44 (0) 24 7630 2437
> Web: www.serck-controls.co.uk  Admin: post at serck-controls.co.uk
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the above.  Any views or opinions presented are solely those of the
> author and do not necessarily represent those of Serck Controls Ltd.
> Please note that Serck Controls Ltd is able to, and reserves the right
> to, monitor e-mail communications passing through its network.
> This email has been checked for viruses.  Serck Controls Ltd shall not
> be responsible for damage caused by any undetected virus.
