NE2000 network card for pc386 supported?
Samuel Konnerth S.Konnerth at alcatel.de
Thu Oct 19 11:05:49 UTC 2000
Hello,
I've tried the recommandations of Hongsong Li and I was succesful,
thanks a lot. I even did not set the IRQ's (because there was no IRQ
parameter in the networkconfig.h). The netdemo example works in the
means of sending arp requests to the host (so I think that the driver
works), but I have problems with the IP adresses. I am using a no name
ne2000 ISA card. If you send me the patch of your ne driver I can check
if it works or not.
Which adresses do I have to configure in the networkconfig.h (I do not
want to use bootp)? Actually I have configured the MAC address of the
target, the IP address of the target and the netmask 255.255.255.0. With
tcpdump on the host I can see after the tftp download of the application
that the target sends an arp to the hosts: <target_name> who has
<target_name>? or similar. And a ping from the host to the target is not
successful, too.
BR,
Samuel.
dk at gentex.ru wrote:
> Wednesday, October 18, 2000, 8:55:57 PM, you wrote:
> SK> Hello,
> SK> I am using a NE2000 ethernet card in my PC. Does the BSP pc386 support
> SK> this card? Because in the bsp.h only 2 cards are defined (dec?? and
> SK> wd??). Does someone of you have this card too and is running the pc386
> SK> with this card?
> Hi
> I use ne2000 clone with pc386. But the original driver for ne2000
> hase some rude errors. Not all ne2000 cards can work properly with it.
> I has re-written ne2000 driver for rtems. It work now at least with
> two my ne-compatible cards. If anyone is interested in I can send the
> patch for ne.c.
> I'd like also to improve some details, but I have not enough time now,
> may be later...
> Sincerely,
> Dmitry Kargapolov, ICQ 54000305, dk at gentex.ru
____________________________________________________
Samuel Konnerth
UMTS SW Development
ALCATEL SEL AG
Radio Communication Division
Lorenzstr. 10
D-70435 Stuttgart
Tel:      +49-711-821 30360 (Alcanet: 2-503 30360)
Telefax:  +49-711-821 42996
GSM:      +49-171-4365156
Email:    S.Konnerth at alcatel.de
Email for life: 98.samuel.konnerth at aist.enst.fr
