I hope this isn't a stupid question...
Thu Oct 19 15:21:40 UTC 2000
Nick.SIMON at syntegra.bt.co.uk wrote:
> > -----Original Message-----
> > From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> > Sent: 19 October 2000 13:52
> > To: Rosimildo da Silva
> > Cc: Gregory.D.Menke.1 at gsfc.nasa.gov; RTEMS mailing list
> > Subject: Re: I hope this isn't a stupid question...
> <big snip>
> > > MANAGERS=io event semaphore timer rate_monotonic signal msg
> > This only impacts the "Classic API.  There is no comparable
> > feature for ITRON or POSIX.
> So if you have POSIX API you automatically get all the managers necessary to
> support it?  Or am I being stupid?
Basically yes to the first question.  But you don't get all of the code
for all of the managers you reference in your executable.
The POSIX code is generally setup as one function per file so you only
link in what you reference.  All of the managers are initialized if
the POSIX API is configured.
The Classic API optional manager support was added when the Classic API
was "one manager per file".  It links in a stub for the manager that
returns "not configured".  This includes a stub for manager
initialization
so the manager is not even initialized.
> -- Nick Simon
