Source code reusability
Ralf Corsepius corsepiu at faw.uni-ulm.de
Mon Oct 23 16:41:33 UTC 2000
Charles-Antoine Gauthier wrote:
> The GCC team recommends the use of __attribute__ over pragma. Look in
> the docs under C extensions, function attributes.
>   Some people object to the `__attribute__' feature, suggesting that
>   ANSI C's `#pragma' should be used instead.  There are two reasons for
>   not doing this.
>     1. It is impossible to generate `#pragma' commands from a macro.
>     2. There is no telling what the same `#pragma' might mean in another
>        compiler.
You're right, however Silverio is probably to the Hitachi SH.
IIRC, there was a time when __attribute__(interrupt)  for the SH was
completely hosed in gcc's SH backend or wasn't even supported at the
time we ported RTEMS to the SH.
Things might have changed since then, but last time I checked for
this issue, it was still present (BTW: Even #pragma interrupt is
broken).
> The documentation also contains:
> `interrupt'
>      Use this option on the M32R/D to indicate that the specified
>      function is an interrupt handler.  The compiler will generate
>      function entry and exit sequences suitable for use in an interrupt
>      handler when this attribute is present.
> `interrupt_handler'
>      Use this option on the H8/300 and H8/300H to indicate that the
>      specified function is an interrupt handler.  The compiler will
>      generate function entry and exit sequences suitable for use in an
>      interrupt handler when this attribute is present.
> Unless you are using either of these CPUs, I would not assume that
> #pragma interrupt does anything.
It is also valid for the SH.
> Silverio Diquigiovanni wrote:
> > Hi to all,
> > I'm aware that this isn't a good request to submit to this mail list,
> > but with faith in your experience in matter of reusable source code I
> > hope you can help me.
> > The question:
> > - I have three compilers which I normally use every day :
> >   Green Hills compiler
> >   GNU gcc compiler
> >   IAR compiler
> > The source code is largely reusable because I use always ANSI compliant
> > normative, but today have a problem with interrupt functions.
> > I must create a mechanism for declarin a function like interrupt
> > function whitout use a compiler dipendent syntax.
> > Green Hills uses :
> >   void interrupt my_fun( void ) { }
> > GNU uses:
> >   #pragma interrupt
> >   void my_fun( void ) { }
> > IAR uses:
> >   void interrupt[vect_num] my_fun( void ) { }
> > My initial idea was be usign a macro to implement the different
> > compiler implementation.
> > #ifdef __GREEN_HILLS__
> >   #define INTERRUPT_FUN(fun,vec)        (.........)
> > #endif
> > #ifdef __GNUC__
> >   #define INTERRUPT_FUN(fun,vec) (#pragma interrupt \ void fun(void))
> > #endif
> > #ifdef __IAR__
> >   #define INTERRUPT_FUN(fun,vec) (void interrupt[vec] fun(void))
> > #endif
> > But #pragma can't be generated by a macro, so the __GNUC__
> > implementation is impossible....
Another (semiportable) alternative is to wrap the interrupt stuff
into inline asm-macros, cf.
src/lib/libcpu/sh/sh7032/score/ispsh7032.c
> > Have you some suggestion about ?
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
http://www.faw.uni-ulm.de
