Source code reusability
Silverio Diquigiovanni silverio.di at qem.it
Tue Oct 24 14:52:50 UTC 2000
Charles-Antoine Gauthier wrote:
> Highly recommended approach. Also, if the timing allows, consider
> using the RTEMS first level interrupt handler. I would never trust a
> compiler to do the right thing (e.g. with some systems, address
> translation may need to be turned back on ASAP). At least, check the
> generated code for sanity.
Perhaps can be, Alejandro Villanueva suggest another mode
Alejandro Villanueva wrote:
> #define INT_PRAGMA #pragma interrupt
> INT_PRAGMA
> void interr( void ) {
>    printf( "Hi there!" );
> int main (void) {
>    printf( "Main is here!" );
> cpp defines.c > defines.pre
> cat defines.pre
> # 1 "defines.c"
> #pragma interrupt
> int main (void) {
> I think that once you obtain this file you can compile it with gcc.
Exist a gcc command to induce the prepocessor to do his work two time ?
Thank you !!!
