PPP & TCP/IP networking
Wed Oct 25 15:03:31 UTC 2000
Nick.SIMON at syntegra.bt.co.uk wrote:
> The last beta was 3a, and preferable to beta 3.  POSIX stuff all works, as
> does the web server.
> Does Joel know POSIX is broken?
It is not broken but there is a transition issue he needs to deal with.
These constants are actually in pthread.h which has moved packages.
pthread.h is now included in the RPMs since it is required to build
multi-thread aware gcc support libraries.  Previously it was in the
RTEMS
source code.  You need to be on beta3a with the RPMs or tool sources
from there.  The cancel constants are there and pthread_cancel() works.
> -- Nick Simon
> > -----Original Message-----
> > From: Matthew J Fletcher [mailto:mfletcher at serck-controls.co.uk]
> > Sent: 25 October 2000 15:29
> > Cc: rtems-users at oarcorp.com
> > Subject: Re: PPP & TCP/IP networking
> > > You are enabling networking, obviously.  With --enable-networking in
> > > configure.  You'll
> > > also need --enable-posix
> > bit of a problem cos in the latest snapshot (2000929) the
> > posix stuff wont
> > build, does this work in the beta /3
> > versions ?, i get problems with,
pthread.h must be provided by your toolset.
> > PTHREAD_CANCEL_DISABLE
> > PTHREAD_CANCEL_ENABLE
> > PTHREAD_CANCEL_ASYNCHRONOUS
> > PTHREAD_CANCEL_DEFERRED
> > and a load of other not being defined,.
> > regards
> > Matthew J Fletcher
> > NPD Firmware
> > Serck Controls Ltd
> > Serck Controls Ltd, Rowley Drive, Coventry, CV3 4FH, UK
> > Tel: 44 (0) 24 7630 5050   Fax: 44 (0) 24 7630 2437
> > Web: www.serck-controls.co.uk  Admin: post at serck-controls.co.uk
> > This email and any files transmitted with it are confidential and
> > intended solely for the use of the individual or entity to whom they
> > are addressed. If you have received this email in error please notify
> > the above.  Any views or opinions presented are solely those of the
> > author and do not necessarily represent those of Serck Controls Ltd.
> > Please note that Serck Controls Ltd is able to, and reserves
> > the right
> > to, monitor e-mail communications passing through its network.
> > This email has been checked for viruses.  Serck Controls Ltd
> > shall not
> > be responsible for damage caused by any undetected virus.
> the system manager.
> This footnote also confirms that this email message has been swept by
> MIMEsweeper for the presence of computer viruses.
> www.mimesweeper.com
