PPP & TCP/IP networking
Wed Oct 25 17:29:05 UTC 2000
Matthew J Fletcher wrote:
> Joel Sherrill wrote:
> > It is not broken but there is a transition issue he needs to deal with.
> > These constants are actually in pthread.h which has moved packages.
> > pthread.h is now included in the RPMs since it is required to build
> > multi-thread aware gcc support libraries.  Previously it was in the
> > RTEMS
> > source code.  You need to be on beta3a with the RPMs or tool sources
> > from there.  The cancel constants are there and pthread_cancel() works.
> there seems to be a full version of pthread.h in my --prefix dir, i
> presume i should be using that istead of the one in the posix/ dir in
> rtems.
They SHOULD be the same file.  There were no changes to the file itself.
It is just now installed as part of newlib rather than RTEMS.  As long
as
your tool installation has it, you are ok.
> regards
> Matthew J Fletcher
> NPD Firmware
> Serck Controls Ltd, Rowley Drive, Coventry, CV3 4FH, UK
> Tel: 44 (0) 24 7630 5050   Fax: 44 (0) 24 7630 2437
> Web: www.serck-controls.co.uk  Admin: post at serck-controls.co.uk
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the above.  Any views or opinions presented are solely those of the
> author and do not necessarily represent those of Serck Controls Ltd.
> Please note that Serck Controls Ltd is able to, and reserves the right
> to, monitor e-mail communications passing through its network.
> This email has been checked for viruses.  Serck Controls Ltd shall not
> be responsible for damage caused by any undetected virus.
