More MPC860 BDM weirdness
Erwin Rol Erwin.Rol at q-soft-engineering.com
Fri Oct 27 09:00:30 UTC 2000
did you used the GDB run or continue command ?
I always use continue after i loaded the programm via BDM
in the target and that all seems to work OK. I never tried the
GDB run command. I think Frank optimized his GDB patch for a linux
PPC target, which might be the problem.
- Erwin
Phil Torre wrote:
> I could swear I've read a description of this problem, but I can't
> find it on any of the mailing lists so here goes...
> My environment is RTEMS 4.5.0 beta3a on an MPC860FADS target,
> downloading through the BDM port using the MPCBDM 2-chip interface
> from VAS-GmbH and accompanying GDB patches.  The host is Linux.
> I can initialize the FADS board from GDB and download hello_world
> just fine.  Memory dump and register read/write work fine, I can
> even single step.  However, as soon as I let the target run (with
> a breakpoint set or not), GDB says "program received SIGINT".  At
> this point, GDB thinks the target is in debug mode, but the target
> is actually still running.  The FRZ line on the BDM port is held
> high, which is why GDB thinks we're stopped.  (I know about JP1 on
> the FADS board; it's set for FRZ rather than VFLS[0:1].)
> Can I (or the BSP?) have something improperly initialized so that
> the 860 asserts FRZ while its still running?  Any ideas?
> Thanks in advance,
> -Phil Torre (ptorre at zetron.com)
