Network buffers, MPC860 and data caching
Eric Norum eric at cls.usask.ca
Sun Oct 29 21:02:01 UTC 2000
Till Straumann wrote:
> Eric Norum wrote:
> > Network receive buffers are allocated by MCLGET, not by malloc.  An mbuf
> > cluster is aligned on a cluster-sized (2 kbyte) boundary.  Network mbufs
> > are aligned on an mbuf-sized (128 byte) boundary.  See bsd_init in
> > src/libnetworking/rtems/rtems_glue.c.  Unless a cache line is larger
> > than an mbuf there should be no problems.
> Sorry, I don't quite agree.
> The point is that the `databuf' starting address, i.e. where the network
> interface
> chip writes data must be cache line aligned. If I count the fields in m_hdr and
> pkthdr,
> I get 7*4 bytes, i.e. the data area is seems to be 4byte aligned. Assuming that
> nobody
> reads any field beyond mh_data while the network interface `owns' the buffer,
> the
> first cache line could be flushed before yielding the buffer to the network
> driver. But this will only
> be enough on a machine with a cache line size <= 5*4 = 20 bytes, e.g. the MPC
> 860.
``What we have here is a failure to communicate.''
We must be looking at different source.  The
c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c in the
snapshot I've got here (rtems-ss-20000929) has neither calls to malloc
nor free.  The CVS ID line is:
  $Id: console-generic.c,v 1.5 2000/08/25 17:25:27 joel Exp $
The receive and transmit buffer areas are:
 *  I/O buffers and pointers to buffer descriptors.
 *  Currently, single buffered input is done. This will work only
 *  if the Rx interrupts are serviced quickly.
 *  TODO: Add a least double buffering for safety.
static volatile char rxBuf[NUM_PORTS][RXBUFSIZE];
static volatile char txBuf[NUM_PORTS];
I agree that there is a problem here since the rxBuf is not aligned on a
cache boundary.  A cache line which overlapped the front or back of the
rxBuf could overwrite the values placed in the rxBuf by the SDMA
channel.  The txBuf isn't a problem, since extra flushes would just
write the same values into txBuf as were placed there by the
rtems_cache_flush_multiple_data_lines call in m8xx_uart_write.  A fix
would be to statically allocate RXBUFSIZE+CACHE_LINESIZE-1 bytes for
each receive buffer, and then to use only the cache-aligned portion of
the buffer.
The network driver uses mbuf clusters for incoming packets.  These are
aligned on 2k boundaries so there's no chance of a cache-line write
scrambling a packet buffer.  Once a packet has been received, all the
cache lines which refer to the data are marked invalid.
Hmm...But there *is* a problem here, too.  It's not related to cache
line boundaries, though.
1) CPU allocates an mbuf cluster and does some writes and reads to the
cluster.  The cache is in writeback mode, so main memory is not updated.
2) CPU frees the mbuf cluster.
3) Driver read task allocates that mbuf cluster.
4) DMA engine starts reading into the mbuf cluster.
5) CPU decides it wants to reuse the cache line in question and flushes
it to main memory -- kaboom -- this overwrites the value stored by the
DMA engine!
I think that this problem could be avoided by marking the cache lines
associated with an mbuf cluster invalid *before* pasing the mbuf cluster
to the DMA engine, instead of after the DMA engine has finished filling
the cluster as is now the case..  The fix would be to call
rtems_cache_invalidate_multiple_data_lines just after the MCLGET.  You
wouldn't have to invalidate all 2kbytes, just the 1536 bytes needed to
hold an ethernet frame.
For transmission, once the stack has passed an mbuf to the driver output
routine, that mbuf is `owned' by the driver so the CPU won't be writing
to the mbuf header after the driver does the
      rtems_cache_flush_multiple_data_lines(txBd->buffer, txBd->length);
All mbufs are aligned on a 128 byte boundary so activity on other mbufs
can not cause a cache-line write to affect an mbuf which has been
flushed to main memory.  Actually, it wouldn't make any difference even
if activity on another mbuf followed by a cache line write *did* cause
the mbuf in question to be written since the value written would be
exacly the same as the value in main memory anyway. The DMA engine would
still see the same value in main memory during the transmission.
It makes no difference if the txBd->buffer is not on a cache line
boundary.  Sure a few bytes of mbuf header get written to main memory
along with the mbuf data, but who cares?  The important thing is that
the bytes from buffer to buffer+length are forced out to main memory
where the DMA engine can see them.
Charles. can you fix the two problems mentioned above?  While you're at
it, could you add support for the FEC so we can get 100baseT Ethernet?
Joel, I wonder if other systems with caches have similar problems?
> Another idea: is it possible to use the M_EXT facility to provide an aligned
> area
> (and a corresponding deallocation routine)?
> Is it legal to change the flags and the extension record on an mbuf obtained
> using
> MGETHEADER()?
Yes, you could use M_EXT but I don't see the need -- at least once the
changes mentioned above have been made.
> > BTW -- I see you're from SLAC.  Are you considering using EPICS with
> > RTEMS?
> Indeed, that's what I'm envisioning. Are you going to OakRidge in November?
> I hope to learn more at the collaboration meeting about the efforts to untackle
> EPICS' OS-dependencies, RTEMS etc. It'd be nice talking to you about these
> issues.
Unfortunately I can't make it to Oak Ridge.  Teaching commitments and
starting a new job make the trip impossible.  An expense-paid trip to
Palo Alto sometime to give a seminar or training course on EPICS/RTEMS
would be ideal :-) but I'll certainly give you what support I can by
e-mail.  I'd really like to see more places using RTEMS with EPICS.
We've got a dozen or so IOC's (68360's) running equipment here and
things seem to be working just great.  It's really convenient having a
<$500 (Canadian!) IOC.  You can use them everywhere.
Canadian Light Source                      Phone: (306) 966-6308
University of Saskatchewan                 FAX:   (306) 966-6058
Saskatoon, Canada.
