Webserver Graphics in flash.
Mon Oct 30 13:43:41 UTC 2000
gerke.kok at tpa-nl.com wrote:
> You should be able to store some graphics in the tar-file that is in the
> web-server example. Althoug I did not work with it.
This is one approach.
I would like to see a "tar reader" filesystem.  It could be a derivative
of the IMFS with memfile replaced.  When you mount the "tar image"
linked
in via the same trick as the httpd demo, the mount builds all the
directory
and file information.  All of that information is the same as with
the IMFS EXCEPT that the actual memory for file contents could simply
be a pointer to the image of the file in the tar image.
You can also use the objcopy binary file trick to turn the graphics
file into a .o and link it with your executable.  Just like the httpd
does with the tar file it generates.
> wkr,
> Gerke
> -----Oorspronkelijk bericht-----
> Van: Matthew J Fletcher [mailto:mfletcher at serck-controls.co.uk]
> Verzonden: Monday, October 30, 2000 10:04
> Aan: rtems-users at oarcorp.com
> Onderwerp: Webserver Graphics in flash.
> Hi,.
> I i have been pondering how to make the web pages we use more fancy, on idea
> was to incorperate
> some token graphics but i am wondering how to do this.
> Currently the web pages are built in c-code and written out when we mount
> the imfs filesystem,
> i am looking for a similar way for binary graphics, without the hastle of
> having to write some
> routines of my own to do it.
> Has anyone done this kind of thing before ?.
> regards
> Matthew J Fletcher
> NPD Firmware
> Serck Controls Ltd, Rowley Drive, Coventry, CV3 4FH, UK
> Tel: 44 (0) 24 7630 5050   Fax: 44 (0) 24 7630 2437
> Web: www.serck-controls.co.uk  Admin: post at serck-controls.co.uk
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the above.  Any views or opinions presented are solely those of the
> author and do not necessarily represent those of Serck Controls Ltd.
> Please note that Serck Controls Ltd is able to, and reserves the right
> to, monitor e-mail communications passing through its network.
> This email has been checked for viruses.  Serck Controls Ltd shall not
> be responsible for damage caused by any undetected virus.
