Sonic ethernet driver
Tue Oct 31 13:50:44 UTC 2000
Antonio da Silva Fariña wrote:
> Jiri Gaisler wrote:
> > I'm using rtems-4.5.0 with this bsp and driver and have not
> > noticed any mismatch.
> Yes, I have a misunderstanding.
I think the sonic libchip driver also should support
detach. So in truth, it's attach needs another parameter
as well.
> The sonic driver must be wrapped with some configuration
> informaton.  There is a example for powerpc but I can´t
> find the equivalent code for the Tharsys Erc32 Board in
> the rtems4.5 distribution.
> Where can I find it ?.
Jiri has this at the moment.  I hope this show up in his
next round of submittals. <hint>
> > However, unless you have reworked the
> > DMA interface on your board, networking will not work due to
> > bugs in the FPGA generating the DMA signals. I have spent
> > a lot of time debugging this problem and also informed Tharsys
> > of suitable solutions, but the problem persists.
> My Lattice Logic Revision is 3. Can I build rtems networking
> aplicattions ?
This is Jiri's. :)
> Thanks
> _______________________________________________________________________
>  DIATEL-UPM                URL:    http://www.diatel.upm.es/~adasilva/
>  EUIT Telecomunicación     mailto: adasilva at diatel.upm.es
>  Ctra. Valencia, Km. 7  Tel: +34 91 3367812   Fax: +34 91 3367817
>  28031 Madrid, SPAIN
> _________________________________________________________________________
