more cache manager issues
Nigel Spon nigel at adi.co.nz
Tue Oct 31 20:21:37 UTC 2000
>One global `free(arg)' function could then determine the heap
>corresponding to the argument
>by comparing the argument pointer to the standard heap / aligned heap
>starting and end addresses.
I dealt with this by having one heap and an allocator which could return
aligned blocks by padding the front of the block and returning a pointer
that was offset 1-3 longwords into the block as necessary. The free
function then checks for the padding words, which are a value that can't
appear in a block header. This allows it to locate the real block header
and free that.
Not terribly elegant, but it works and has one heap and one free...
