C++ for embedded systems
angelo
angelo at hunterlink.net.au
Wed Oct 11 00:49:41 UTC 2000
I seem to be having the problem also that I am not linking with the standard
C++ libraries also.
for the following file, I get the link error following. What must be done to
solve this?
#include <iostream>
#include <fstream>
int x ()
ifstream testfile ("testfile");
if (testfile)
cout <<"testfile opened"<<endl;
testfile.close();
else
cout<<"unable to open file"<<endl;
return 1;
Error message
/opt/rtems/bin/i386-rtems-gcc --pipe -B/opt/rtems//pc386/lib/ -specs bsp_specs
qrtems -g -Wall -ansi -fasm -O4 -L /opt/rtems//pc386/lib
-Wl,-Ttex
t,0x00100000 -o o-optimize/smart.obj o-optimize/mainline.o
o-optimize/testcpp.
o /opt/rtems//pc386/lib/no-dpmem.rel /opt/rtems//pc386/lib/no-event.rel
/opt/rt
ems//pc386/lib/no-msg.rel /opt/rtems//pc386/lib/no-mp.rel
no-part.rel /opt/rtems//pc386/lib/no-signal.rel
/opt/rtems//pc386/lib/no-timer.r
el /opt/rtems//pc386/lib/no-rtmon.rel
o-optimize/testcpp.o: In function `x(void)':
/home/angelo/SmartControl/source/hal_rtems/testcpp.cpp:6: undefined reference
to
`ifstream::ifstream(int, char const *, int, int)'
/home/angelo/SmartControl/source/hal_rtems/testcpp.cpp:7: undefined reference
to
`ios::operator void *(void) const'
/home/angelo/SmartControl/source/hal_rtems/testcpp.cpp:9: undefined reference
to
`endl(ostream &)'
to
`cout'
to
`ostream::operator<<(char const *)'
to
`ostream::operator<<(ostream &(*)(ostream &))'
/home/angelo/SmartControl/source/hal_rtems/testcpp.cpp:10: undefined reference
o `fstreambase::close(void)'
/home/angelo/SmartControl/source/hal_rtems/testcpp.cpp:14: undefined reference
o `endl(ostream &)'
o `cout'
o `ostream::operator<<(char const *)'
o `ostream::operator<<(ostream &(*)(ostream &))'
/home/angelo/SmartControl/source/hal_rtems/testcpp.cpp:17: undefined reference
o `ifstream::~ifstream(void)'
collect2: ld returned 1 exit status
make: *** [o-optimize/smart.exe] Error 1
Nick.SIMON at syntegra.bt.co.uk wrote:
> Are you really sure you want objects in ROM? They wouldn't be very
> dynamic!
> We have lots of C++ code running under RTEMS. Objects, whether globals or
> dynamically created, live in RAM. Snags are:
> (1) Performance is hit somewhat by the code inserted by the compiler for
> exception handling. I haven't found a way to disable this in the compiler,
> else we'd do without EH for performance's sake.
> (2) Link has to be just right (in file linkcmds in the BSP) if you want
> global constructors to work.
> Best wishes
> -- Nick Simon
> > -----Original Message-----
> > From: Peter Mueller [mailto:peter.o.mueller at gmx.de]
> > Sent: 08 October 2000 19:18
> > To: rtems-users at oarcorp.com
> > Subject: C++ for embedded systems
> > Hi all,
> > I want to use C++ for a project with rtems. No problems so
> > far. But I'm
> > very unsure how to write C++ code that "is good" for embedded systems.
> > Especially how can I make sure an object can be in ROM ...
> > Is there a good tutorial ... about points to consider when
> > developing C++
> > code for embedded systems. I know the EC++ stuff a bit, but
> > there is no info
> > about my memory related questions there.
> > Thanks,
> > Peter
> > Sent through GMX FreeMail - http://www.gmx.net
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://users.hunterlink.net.au/~maaaf/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
