Can i386-rtems-gcc support a RTOS like Vrtx/spm?
Tue Oct 17 13:41:07 UTC 2000
guobing at sohu.com wrote:
> Hi,anyone.As we know,rtems is running on FPM(flat protected mode).Recently I've a reseach project in which I want to use i386-rtems-gcc toolchain to support a RTOS like vrtx/spm.This RTOS is running on SPM(safety protected mode) and the target CPU is X86.How to begin my research project?Any advice can be approciated.
The i386-rtems-gcc target is more than just a compiler to generate i386
code.  It includes
information about the target OS for run-time information (thread-safe
C++ STL for example)
and the newlib C Library configuration is specially tailored for RTEMS.
So the target i386-rtems-gcc
is not what you want.
Follow that can I use an embedded i386 GNU tools configuration.  The
answer is "it depends".
What object format is the code using?  What C library are you going to
use?  Should the
generated code be flat-mode or some special 48 bit segment:offset
setup?
> ËѺüÎÒÕÒÄ㣺http://icqdownload.sohu.com
> ËѺü£ºhttp://www.sohu.com
