I hope this isn't a stupid question...
Rosimildo da Silva
rdasilva at connecttel.com
Thu Oct 19 12:43:51 UTC 2000
Gregory.D.Menke.1 at gsfc.nasa.gov wrote:
> > > I've got our app compiling, sucessfully linking, and starting on our
> > > powerpc target. My current intractable problem is the call;
> > > sem_open("top_sem", O_CREAT, 0777, 0);
> > > sem_open("top_sem", O_CREAT, 0, 0); also failed identically.
> > > which is failing with -1; perror() reports no space left on device.
> > > This is the first of a couple of semaphores created by the app.
> > > I'm using the posix api, no itron, no c++ and no networking. I have
> > > all the posix config #defines set up to reasonable values.
> > > Is there some additional initialization I need to perform?
> > yes. You need to define the resources for the POSIX api:
> > I defined them as: ( change them to match your needs ).
> > #define CONFIGURE_MAXIMUM_POSIX_THREADS 128
> > #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 128
> > #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 128
> > #define CONFIGURE_MAXIMUM_POSIX_KEYS 128
> > #define CONFIGURE_MAXIMUM_POSIX_TIMERS 100
> > #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 100
> > #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 100
> > #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 100
> Mine are down at 30- but they are all there, and the call is failing
> on the first semaphore open.
Sorry. I did not read between the lines that you had a good
configuration.
Another area to check, is to make sure that you're including the
"real" managers. Add something like that to your makefile:
MANAGERS=io event semaphore timer rate_monotonic signal msg
Rosimildo da Silva rdasilva at connectel.com
ConnectTel, Inc. Austin, TX -- USA
Phone : 512-338-1111 Fax : 512-918-0449
Mobile: 512-632-7579
Company Page: http://www.connecttel.com
Home Page: http://members.xoom.com/rosimildo/
