compiling cont.
russ
russ at embedit.com.au
Mon Oct 23 05:53:46 UTC 2000
This has now been resolved (thanks again Joel!). Removing the
soft-float flag fixed everything.
Now my next question, has much changed in the system configuration
process from 4.0 to 4.5? I've read the "Configuring a system using the
template confdefs.h" README and think I've gotten everything.
But my Init task isn't being called. I get into
_Thread_Start_multitasking and when the first _Context_Switch is
called, it crashes.
Thanks
russ
Joel Sherrill wrote:
> I don't know if this is resolved or not. First __umodsi3 should be
> coming from the RPMs. It looks like you are not linking against the
> correct multilib version. Try adding a -Map to the link arguments
> and seeing where it comes from.
> russ wrote:
> > Hi,
> > I found that I can narrow the problem down to this:
> > c code: long1 = long2 % long3; -> crashes
> > asm: jsr __umodsi3
> > c code: short1 = short2 % short3; -> works
> > asm: divu.w 14(%sp),%d0
> > My question is, would __umodsi3 be a function in the pre-built
> > libraries I downloaded in RPM form and if so, how would I know if the
> > rpm library was compiled with the m68000 flag or the m68020 flag?
> > Thanks
> > russ
> > Charles-Antoine Gauthier wrote:
> > > russ wrote:
> > > > Hi,
> > > > This is a better example of my problem. This is the output when I compile a single file from the
> > > > command line:
> > > > russ > m68k-rtems-gcc -v -I/opt/rtems/bare-m68302/lib/include heapallocate.c
> > > > Reading specs from /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/specs
> > > > gcc version 2.95.2 19991024 (release)
> > > > /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/cpp -lang-c -v -I/opt/rtems/bare-m68302/lib/include
> > > > -D__GNUC__=2 -D__GNUC_MINOR__=95 -Dmc68000 -Drtems -D__rtems__ -D__ELF__ -D__mc68000__ -D__rtems__
> > > > -D__rtems__ -D__ELF__ -D__mc68000 -D__rtems -Asystem(rtems) -Acpu(mc68000) -Acpu(m68k)
> > > > -Amachine(m68k) -Dmc68000 -D__mc68000 -D__mc68000__ heapallocate.c /tmp/cciqFySH.i
> > > > GNU CPP version 2.95.2 19991024 (release) (68k, Motorola syntax)
> > > > #include "..." search starts here:
> > > > #include <...> search starts here:
> > > > /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/include
> > > > /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68k-rtems/include
> > > > End of search list.
> > > > The following default directories have been omitted from the search path:
> > > > /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../include/g++-3
> > > > /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68k-rtems/sys-include
> > > > End of omitted list.
> > > > /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/cc1 /tmp/cciqFySH.i -quiet -dumpbase heapallocate.c
> > > > -version -o /tmp/ccQjQxOm.s
> > > > GNU C version 2.95.2 19991024 (release) (m68k-rtems) compiled by GNU C version 2.7.2.3.
> > > > /opt/rtems/m68k-rtems/bin/as -mc68000 -o /tmp/ccgd17n4.o /tmp/ccQjQxOm.s
> > > > /tmp/ccQjQxOm.s: Assembler messages:
> > > > /tmp/ccQjQxOm.s:22: Error: invalid instruction for this architecture; needs 68020 or 68030 or 68040
> > > > or 68060 or cpu32 -- statement `divul.l 20(%a0),%d1:%d0' ignored
> > > > The m68k I use is for the 68000, not the 68020, but the assembler wants 68020. Is this built into
> > > > the rpm's? Do I have to rebuild everything from source and not use the rpm's. Or is there something
> > > > I'm missing?
> > > > Thanks
> > > > russ
> > > Seems to me your assembler is bitching about getting 68020 code but was
> > > told to assemble for the 68000. It is complaining that it was given
> > > instructions that do not exist on the 68000. Somehow, your compiler is
> > > not compiling for the 68000, but for the default 68020.
> > > Also, your bsp_specs file is wrong if your compiler does not understand
> > > -qrtems. Check against other working targets, such as the mvme167 or
> > > gen68360.
> > > Institute for Information Technology Institut de technologie de
> > > l'information
> > > National Research Council of Canada Conseil national de recherches du
> > > Canada
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
