Sonic ethernet driver
Antonio da Silva Fariña adasilva at diatel.upm.es
Tue Oct 31 09:55:41 UTC 2000
Jiri Gaisler wrote:
> I'm using rtems-4.5.0 with this bsp and driver and have not
> noticed any mismatch.
Yes, I have a misunderstanding.
The sonic driver must be wrapped with some configuration
informaton.  There is a example for powerpc but I can´t
find the equivalent code for the Tharsys Erc32 Board in
the rtems4.5 distribution.
Where can I find it ?.
> However, unless you have reworked the
> DMA interface on your board, networking will not work due to
> bugs in the FPGA generating the DMA signals. I have spent
> a lot of time debugging this problem and also informed Tharsys
> of suitable solutions, but the problem persists.
My Lattice Logic Revision is 3. Can I build rtems networking
aplicattions ?
Thanks
_______________________________________________________________________
 DIATEL-UPM                URL:    http://www.diatel.upm.es/~adasilva/
 EUIT Telecomunicación     mailto: adasilva at diatel.upm.es
 Ctra. Valencia, Km. 7  Tel: +34 91 3367812   Fax: +34 91 3367817
 28031 Madrid, SPAIN
_________________________________________________________________________
