more cache manager issues
Eric Norum
eric at cls.usask.ca
Tue Oct 31 20:54:08 UTC 2000
Till Straumann wrote:
> An alternative to this approach would be letting
> rtems_cache_aligned_malloc()
> using its own heap with a bigger (cache aligned) granularity.
Yes, but now there's another configuration parameter to be dealt with.
Deciding on where to split the heaps adds more of a burden to the
application programmer.
> One global `free(arg)' function could then determine the heap
> corresponding to the argument
> by comparing the argument pointer to the standard heap / aligned heap
> starting and end addresses.
> Even more elegant would of course be an object oriented approach with a
> virtual `free' member
> function (or a field in the block header holding the information about
> which version of `free' must
> be used for that specific block of memory).
Yep. Maybe the memory allocation routines (both regular and cache
aligned) should be rewritten to do this.
> IMHO, the need to call a `special' deallocator function is very error
> prone.
Agreed.
My quick solution to the problem wasn't very good.
I'm not yet convinced that dual heaps is a good idea, though.
Eric Norum eric at cls.usask.ca
Canadian Light Source Phone: (306) 966-6308
University of Saskatchewan FAX: (306) 966-6058
Saskatoon, Canada.
