4.5.0-beta3a build problems
Mon Sep 18 18:53:11 UTC 2000
Martti Kuparinen wrote:
> Hi!
> I'm running FreeBSD 4.1-STABLE with the following packages installed:
> Making all in build
> gmake[2]: Entering directory `/home/martti/tmp/rtems/build/tools/build'
> i386-rtems-gcc -DHAVE_CONFIG_H -I. -I../../../source/rtems-4.5.0-beta3a/tools/build -I.     -g -O2 -c ../../../source/rtems-4.5.0-beta3a/tools/build/cklength.c
> ../../../source/rtems-4.5.0-beta3a/tools/build/cklength.c:35: memory.h: No such file or directory
> gmake[2]: *** [cklength.o] Error 1
James... this is not a problem with your cross tools.  cklength.c is
a native program.  Why is the cross compiler being used to build
native programs?
Martti.. do you have CC set in your environment?
