4.0 -> 4.5
russ russ at embedit.com.au
Wed Sep 20 00:46:35 UTC 2000
I'm using the bit_rtems script. I'll give that a go.
Thanks
russ
Joel Sherrill wrote:
> russ wrote:
> > Hi,
> > First I'd like to say you've done a great job with the rpm's. I'm just converting from 4.0 to 4.5
> > and it only took me a day to get 4.5 up and running. That includes download time. Thanks!
> > My question has to do with building for the bare m68k. I'm sure this has been discussed previously
> > on the list. But I believe rtems is defaulting to 68020 command set, not 68000.
> > Is there a switch or parameter of the bit_rtems script or a specific makefile where the 68000
> > command set can be forced?
> Are you building the bare BSP something like this?
> ..../rtems/configure --target=m68k-rtems \
> '--enable-bare-cpu-cflags= -m68000' \
> --enable-rtemsbsp="bare" \
> --enable-bare-cpu-model=m68000
> If you left out bare-cpu-cflags, then it would default to the
> 68020 as that is gcc's default.
> > Thanks
> > russ
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
