Network config issue
Mon Sep 25 14:30:03 UTC 2000
Jake Janovetz wrote:
> How would the configuration be changed after compile, then?
> Are you saying that once you build the application, you're stuck
> with that network configuration?  If this is the case, then I
> strongly disagree.  It would kinda suck if Red Hat shipped
> Linux with one network configuration.
No it would be a default configuration used normally just
to satisfy linking.  You can't tell it now but there is
already one in librtems.  See c/src/libmisc/dummy.
> Same goes with an embedded OS that may go into devices that
> should be reconfigurable.  I must be misunderstanding something,
> though.
This does not diminish the reconfigurability.  It just sets things
up so it is easier to build tests and run autoconf checks.
Charles... this has not been merged for 1 very important reason.
If you have a default network configuration, then the autoconf test
for select() will pass and believe RTEMS' select works for ALL
cases.  The RTEMS select() implementation only works on sockets
so this would be broken.  I know this impacts TCL.
Ignoring the above breakage, I think it is the right thing to do.
Also .. I would like to see some automated networking tests and
if we had a loopback configuration that was sufficient to run
TCP/IP on a non-networked device, then we could have these.
--joel
>    Jake
> On Mon, Sep 25, 2000 at 09:29:47AM -0400, Charles-Antoine Gauthier wrote:
> > Has there been any work done to move the network config info into the
> > RTEMS main source tree somehow?
> > I am trying to build a new library to support running the libgcj/mauve
> > tests using the dejagnu framework. This library is basically a C stub
> > that calls a C function emitted by jvgenmain, which in turns calls the
> > main Java function. My problem is that I am now introducing a new
> > library in RTEMS, and that the tests need to have the network
> > configuration defined. Hence, I would like to have a mechanism by which
> > the network configuration is defined at the time RTEMS is build.
> > I believe that Eric Norum was thinking about integrating the networking
> > tests into the main tree. The same issue would occur in that situation.
> > How about putting the network config info in the bsp-specific config
> > files in rtems/make/custom in the form of preprocessor constants? The
> > structures to initialize the network can then be initialized with these
> > constants.
> > Institute for Information Technology   Institut de technologie de
> > l'information
> > National Research Council of Canada    Conseil national de recherches du
> > Canada
>    janovetz at uiuc.edu    | How can it be that mathematics, being after all a
>  University of Illinois | product of human thought independent of experience,
>                         | is so admirably adapted to the objects of reality?
>         PP-ASEL         |                                  - Albert Einstein
> Disclaimer: The policies of this University certainly do not reflect my
>             own opinions, objectives, or agenda.
