Network config issue
Eric Norum eric at cls.usask.ca
Mon Sep 25 14:46:00 UTC 2000
Charles-Antoine Gauthier wrote:
> Has there been any work done to move the network config info into the
> RTEMS main source tree somehow?
> I am trying to build a new library to support running the libgcj/mauve
> tests using the dejagnu framework. This library is basically a C stub
> that calls a C function emitted by jvgenmain, which in turns calls the
> main Java function. My problem is that I am now introducing a new
> library in RTEMS, and that the tests need to have the network
> configuration defined. Hence, I would like to have a mechanism by which
> the network configuration is defined at the time RTEMS is build.
> I believe that Eric Norum was thinking about integrating the networking
> tests into the main tree. The same issue would occur in that situation.
> How about putting the network config info in the bsp-specific config
> files in rtems/make/custom in the form of preprocessor constants? The
> structures to initialize the network can then be initialized with these
> constants.
No, I don't think that's the best place.  The network configuration
should be selectable at application-build time, not at BSP-build time.
For the BSP-specific stuff there are macros for
RTEMS_BSP_NETWORK_DRIVER_NAME and RTEMS_BSP_NETWORK_DRIVER_ATTACH.
If anything, the network configuration should be merged into confdefs.h
with a bunch of preprocessor macros to set the appropriate fields, eg.:
	CONFIGURE_RTEMS_ENABLE_NETWORKING	(0 or undefined, no network
configuration done)
	CONFIGURE_RTEMS_NETWORKING_USE_BOOTP
	CONFIGURE_RTEMS_NETWORKING_ENABLE_LOOPBACK	(0 or undefined, no loopback
interface)
	CONFIGURE_RTEMS_NETWORKING_TASK_PRIORITY
etc.
Canadian Light Source                      Phone: (306) 966-6308
University of Saskatchewan                 FAX:   (306) 966-6058
Saskatoon, Canada.
