rtems_rate_monotonic_period bug?
Wed Sep 27 15:55:51 UTC 2000
My reading of the code agrees with yours.  I have a fairly
simple fix in mind and can describe it to you.  You should
be able to implement it based on that.
I would like a simple test application to demonstrate this.  I think
something like this is enough:
    create the period
    Time0 = _Watchdog_Ticks_since_boot;
    rtems_rate_monotonic_period(periodId, 10);
    Time1 = _Watchdog_Ticks_since_boot;
    rtems_rate_monotonic_period(periodId, 90);
    Time2 = _Watchdog_Ticks_since_boot;
    print all the times
This can be a simple non-loop init.c based on hello world.
The fix is to add a "next_length" to the period structure in
exec/rtems/include/rtems/rtems/ratemon.h.  Then set that
field where appropriate in the ratemon code including the
path in ratemonperiod.c you identified.
The key change is that the code in ratemontimeout.c should
not use _Watchdog_Reset any longer.  The watchdog timer
is already off the chain and we need to do that 1/2 of
reset.  The reset calls should be changed to this:
  _Watchdog_Insert_ticks(
    &the_period->Timer, the_period->Timer.next_length );
That should do it.  It really shoudl not be that many changes.
I would appreciate a test case and patch.
If given just a test case, I can't say when a patch would show
up.
--joel
Stephan Merker wrote:
> It seems to me that rtems_rate_monotonic_period() doesn't work as expected
> if I'm using changing period lengths (e.g. as done in the example at page
> 181 of the C users manual). The first period is used throughout the lifetime
> of the period.
> E.g.:
> while (1) {
>     do1();
>     do2();
> I would expect do1() to be executed at 0 ticks and do2() at 10 ticks.
> Overall cycle would be 100 ticks. What I get is do1() at 0 ticks, do2() at
> 10 ticks, overall cycle is 20 ticks.
> Having a look in the source ratemonperiod.c, there is no reference to the
> length parameter in state RATE_MONOTONIC_ACTIVE. A bug?
> I'm using RTEMS 4.5 beta3 on Linux.
> Please send a replay to my email directly.
> Thanks,
> Stephan
> | Stephan Merker                merker at decrc.abb.de |
> | DECRC/A4                                          |
> | ABB Corporate Research    http://www.decrc.abb.de |
> | Speyerer Strasse 4,  D-69115 Heidelberg,  Germany |
> | Phone:+49-6221-596218         Fax:+49-6221-596253 |
