Getting Started ( hello_wrorld_c trouble )
Chang Lyong Kim
clkim at pacific.mps.ohio-state.edu
Thu Sep 28 13:56:36 UTC 2000
Dear,
I am trying to install RTEMS for C/C++ on RedHat6.2 Linux PC.
I found these things and installed very quickly.
m68k-rtems-binutils-2.9.5.0.24-1.i386.rpm
m68k-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
m68k-rtems-gdb-4.18-4.i386.rpm
rtems-base-binutils-2.9.5.0.24-1.i386.rpm
rtems-base-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
rtems-base-gdb-4.18-4.i386.rpm
Then, I followed RTEMS installation procedure from "Getting Started..."
configure --target=m68k-rtems --prefix=/usr/local/cross
make RTEMS_BSP="gen68360"
make install RTEMS_BSP="gen68360"
No problem here.
Then, when I tried to compile test.c under hello_world_c.tgz,
I got the following error.
/opt/rtems/bin/m68k-rtems-gcc --pipe -B/usr/local/cross//gen68360/lib/
-specs bsp_specs -qrtems -g -Wall -ansi -fasm -O4 -fomit-frame-pointer
-mcpu32 -c -o o-optimize/test.o test.c
In file included from test.c:28:
/usr/local/cross/gen68360/lib/include/confdefs.h:1005: #error
"CONFIGURATION ERROR: No tasks or threads configured!!
#endif
* Make sure at least one of the initialization task/thread
* tables was defined.
#if !defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE) &&
!defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) &&
!defined(CONFIGURE_ITRON_INIT_TASK_TABLE)
#error "CONFIGURATION ERROR: No initialization tasks or threads
configured!!
make: *** [o-optimize/test.o] Error 1
When I removed
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_INIT
#include <confdefs.h>
from test.c,
it produced,
-mcpu32 -L /usr/local/cross//gen68360/lib -o o-optimize/test.exe
o-optimize/test.o /usr/local/cross//gen68360/lib/no-dpmem.rel
/usr/local/cross//gen68360/lib/no-event.rel
/usr/local/cross//gen68360/lib/no-msg.rel
/usr/local/cross//gen68360/lib/no-mp.rel
/usr/local/cross//gen68360/lib/no-part.rel
/usr/local/cross//gen68360/lib/no-signal.rel
/usr/local/cross//gen68360/lib/no-timer.rel
/usr/local/cross//gen68360/lib/no-rtmon.rel
/usr/local/cross//gen68360/lib/librtemsall.a(bootcard.o): In function
`boot_card':
/home/clkim/rtems/tools/rtems_build/m68k-rtems/c/gen68360/lib/libbsp/m68k/gen68360/startup/../../../../../../../../../rtems-4.5.0-beta3a/c/src/lib/libbsp/m68k/gen68360/startup/../../../shared/bootcard.c:93: undefined
reference to `Configuration'
..........BlaBla...
Any comment is welcome!!!
Thank you very much,
Chang
