>===== Original Message From Alejandro Villanueva <190921 at cepsz.unizar.es> ===== >What's happening in here? The assembly code is ok and I don't find any >docs about issuing BIOS interrupts. Did you switch back to real mode? RTEMS runs in protected mode, so I think you have to issue real mode instructions for BIOS calls to work. -- Chris Caudle
