Non-blocking socket still blocking!
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Sep 1 21:25:07 UTC 2000
Eric N read this carefully and see if I am on the money.
[And no comments about the libio flags being a pain. I
know... the extra mapping causes nothing but trouble...
I think we introduced a minor glitch when we added the
RTEMS filesystem infrastructure. Gene.. follow this logic..
You call fcntl() which sets things for the file descriptor
in a generic sense. And it seems to correctly get to
rtems_bsdnet_fcntl(). But it checks for (iop->flags & O_NONBLOCK).
Unfortunately, the fcntl() routine mapped the bits into internal
settings. Since O_NONBLOCK is 0x4000 and LIBIO_FLAGS_NO_DELAY
is 0x0001, the code fails to note that iop->flags has changed.
So try this patch and let us all know.
Index: rtems/rtems_syscall.c
RCS file: /usr1/CVS/rtems/c/src/libnetworking/rtems/rtems_syscall.c,v
retrieving revision 1.14
diff -u -r1.14 rtems_syscall.c
--- rtems/rtems_syscall.c 2000/06/12 15:00:08 1.14
+++ rtems/rtems_syscall.c 2000/09/01 16:23:38
@@ -730,7 +730,7 @@
rtems_bsdnet_semaphore_release ();
return EBADF;
- if (iop->flags & O_NONBLOCK)
+ if (iop->flags & LIBIO_FLAGS_NO_DELAY)
so->so_state |= SS_NBIO;
else
so->so_state &= ~SS_NBIO;
"Smith, Gene" wrote:
> I noticed that my read() on a supposedly non-blocking socket still blocked
> after
> I had read all data from the socket and called read() again. I then checked
> the socket flags more closely to make sure I was really setting it
> non-blocking
> (O_NONBLOCK is 0x4000) with the following code:
> /* set new_sock non-blocking */
> flags = 0;
> flags = fcntl( new_sock, F_GETFL, 0);
> DTRACE(("\nOrig flags = 0x%x", flags));
> flags = flags | O_NONBLOCK;
> DTRACE(("\nflags|O_NON_BLOCK=0x%x", flags));
> if ( fcntl( new_sock, F_SETFL, flags ) < 0)
> RTEMS_PANIC(("\nCan't set new_sock non-blocking"));
> DTRACE(("\nflags set to 0x%x", flags));
> /* verify non-blocking flag set */
> flags = 0;
> if ( (flags & O_NONBLOCK) == 0 )
> DTRACE(("\nBad flags = 0x%x", flags));
> else
> DTRACE(("\nGood flags = 0x%x", flags));
> The following output trace indicates that my attempt to set the socket
> non-blocking does not "stick." (The value "new_sock" is the return value
> from
> accept().) Any ideas why the socket seems to remain blocking?
> Orig flags = 0x2
> flags|O_NON_BLOCK=0x4002
> flags set to 0x4002
> Bad flags = 0x2
> --Gene
joel at OARcorp.com On-Line Applications Research
