Linking application and BSP
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Sep 21 20:35:44 UTC 2000
I could be very wrong but I think the -qrtems HAS to be after the
"-B.../ -specs bsp_specs" since it has no meaning until the bsp_specs
is processed.
--joel
"Michael P. Collins on korat" wrote:
> I'm still having problems.
> My bsp_specs file is the one used in efi332. The one from gen68340 is
> essentially identical, and yields the same result -- I must have "start.o"
> in my build directory or the final link fails. My Makefile and the
> gcc output are appended. Perhaps there's a clue in there. Comments
> follow.
> # %M% %I%
> # Top-level Makefile for MC68331-based characterization system.
> # Latest delta: %E% %U%
> # Retrieved: %D% %T%
> ROM_LIBPATH = /usr/local/rtems/lz120_ROM/lib
> CPU_FAMILY = mcpu32
> AS = m68k-rtems-as
> CC = m68k-rtems-gcc
> ASFLAGS = -f
> CFLAGS = \
> -qrtems \
> -Wall \
> -ansi \
> -$(CPU_FAMILY) \
> -Wno-unused
> LFLAGS = \
> --pipe \
> -qrtems \
> -Wall \
> -ansi \
> -fasm \
> -$(CPU_FAMILY) \
> -Wno-unused
> OBJECTS = \
> cmd/adc.o \
> cmd/baud.o \
> cmd/bf.o \
> cmd/dac.o \
> cmd/go.o \
> cmd/help.o \
> cmd/led.o \
> cmd/load.o \
> cmd/md.o \
> cmd/mm.o \
> cmd/rev.o \
> cmd/sc.o \
> cmd/sine.o \
> init/init.o \
> lib/atolx.o \
> lib/b_hatoi.o \
> lib/checksum.o \
> lib/inpstr.o \
> lib/parse.o \
> lib/prntln.o \
> lib/read_record.o \
> lib/s_hatoi.o \
> lib/updcrc.o \
> cli/cli.o \
> qsm/qspi_init.o \
> qsm/qspi_rd.o \
> qsm/qspi_wr.o \
> sys/sys_init.o \
> sys/sys_sv.o
> all:
> rm -f rom.s19
> $(MAKE) rom
> rom:
> cd cmd; $(MAKE) objects
> cd init; $(MAKE) objects
> cd lib; $(MAKE) objects
> cd cli; $(MAKE) objects
> cd qsm; $(MAKE) objects
> cd sys; $(MAKE) objects
> $(CC) $(CFLAGS) -v --pipe -B$(ROM_LIBPATH) \
> --specs $(ROM_LIBPATH)/bsp_specs \
> -o rom.o \
> $(OBJECTS) \
> $(LFLAGS) -L $(ROM_LIBPATH) \
> -Xlinker -Map -Xlinker lz120_ROM.map -Xlinker --cref
> m68k-rtems-objcopy -O srec rom.o rom.s19
> clean:
> rm -f rom.s19 rom.map $(OBJECTS)
> Makefile comments:
> The options are a combination of those I've used with this application
> under 4.0 and what are used when the sample applications are built. I
> can't find any documentation for "--pipe" and I don't understand the
> purpose of "-B", nor do they have any effect on the result that I can
> tell.
> Something I don't understand from the sample applications build is
> the inclusion of a number of ".rel" files (i.e., <bsp>/lib/no-event.rel).
> Is there any reason I should link these into my application? It seems to
> work just fine when references are resolved from the libraries.
> Final link output:
> m68k-rtems-gcc -qrtems -Wall -ansi -mcpu32 -Wno-unused -v --pipe -B/usr/local/rtems/lz120_ROM/lib \
> --specs /usr/local/rtems/lz120_ROM/lib/bsp_specs \
> -o rom.o \
> cmd/adc.o cmd/baud.o cmd/bf.o cmd/dac.o cmd/go.o cmd/help.o cmd/led.o cmd/load.o cmd/md.o cmd/mm.o cmd/rev.o cmd/sc.o cmd/sine.o init/init.o lib/atolx.o lib/b_hatoi.o lib/checksum.o lib/inpstr.o lib/parse.o lib/prntln.o lib/read_record.o lib/s_hatoi.o lib/updcrc.o cli/cli.o qsm/qspi_init.o qsm/qspi_rd.o qsm/qspi_wr.o sys/sys_init.o sys/sys_sv.o \
> --pipe -qrtems -Wall -ansi -fasm -mcpu32 -Wno-unused -L /usr/local/rtems/lz120_ROM/lib \
> Reading specs from /usr/local/rtems/lib/gcc-lib/m68k-rtems/2.95.2/specs
> Reading specs from /usr/local/rtems/lz120_ROM/lib/bsp_specs
> rename spec cpp to old_cpp
> rename spec lib to old_lib
> rename spec endfile to old_endfile
> rename spec startfile to old_startfile
> rename spec link to old_link
> gcc version 2.95.2 19991024 (release)
> /usr/local/rtems/lib/gcc-lib/m68k-rtems/2.95.2/collect2 -dc -dp -N -e start -o rom.o start.o /usr/local/rtems/lib/gcc-lib/m68k-rtems/2.95.2/crti.o /usr/local/rtems/lib/gcc-lib/m68k-rtems/2.95.2/crtbegin.o -L /usr/local/rtems/lz120_ROM/lib -L/usr/local/rtems/lz120_ROM/lib -L/usr/local/rtems/lib/gcc-lib/m68k-rtems/2.95.2/mcpu32 -L/usr/local/rtems/lib/gcc-lib/m68k-rtems/2.95.2 -L/usr/local/rtems/m68k-rtems/lib/mcpu32 -L/usr/local/rtems/m68k-rtems/lib cmd/adc.o cmd/baud.o cmd/bf.o cmd/dac.o cmd/go.o cmd/help.o cmd/led.o cmd/load.o cmd/md.o cmd/mm.o cmd/rev.o cmd/sc.o cmd/sine.o init/init.o lib/atolx.o lib/b_hatoi.o lib/checksum.o lib/inpstr.o lib/parse.o lib/prntln.o lib/read_record.o lib/s_hatoi.o lib/updcrc.o cli/cli.o qsm/qspi_init.o qsm/qspi_rd.o qsm/qspi_wr.o sys/sys_init.o sys/sys_sv.o -Map lz120_ROM.map --cref -lgcc --start-group -lrtemsall -lc -lgcc --end-group -T linkcmds -lgcc /usr/local/rtems/lib/gcc-lib/m68k-rtems/2.95.2/crtend.o /usr/local/rtems/lib/gcc-lib/m68k-rtem!
> s/2.95.2/crtn.o
> /usr/local/rtems/m68k-rtems/bin/ld: cannot open start.o: No such file or directory
> collect2: ld returned 1 exit status
> m68k-rtems-gcc: file path prefix `/usr/local/rtems/lz120_ROM/lib' never used
> make: *** [rom] Error 1
> The "file path prefix never used" warning is apparently related to
> the "-B" option, as it goes away if that option is removed. If I put
> "start.o" in the build directory, I get a working binary.
> Any suggestions?
> -- MC --
joel at OARcorp.com On-Line Applications Research
