Network buffers, MPC860 and data caching
Gunter Magin
magin at skil.camelot.de
Mon Sep 25 16:06:30 UTC 2000
Hi,
On Mon, Sep 25, 2000 at 04:24:56PM +0100, Nick.SIMON at syntegra.bt.co.uk wrote:
> I'd like to use data caching to speed things up on my MPC860-based board.
This is a good idea. It will give you quite a boost, esp. in write-back mode.
> However, buffers used by the SCCs e.g. for network transmit & receive must
> not be in cached memory. To achieve this I intend to reserve a chunk of
> memory which has caching turned off. This means the network buffers have to
> be allocated from this reserved memory.
> Does anyone know of a tidy way to take control of the network stack's buffer
> allocation?
Have a look at Charles Gauthier's & Darlene Steward's MBX BSP in the
current snapshot. It goes a different route: All RAM is cacheable,
however, once CPM buffers (not only for network) are touched, explicit
cache commands for the memory covered by the buffer are used:
- on output buffers, caches are flushed after writing and before
setting the ready bit
- on read, the cache lines for the buffer are invalidated before
reading the buffer
Fiddling with the MMU on a 8xx is tricky, and general MMU support in RTEMS
is only rudimentary. For all 8xx BSPs (eth_comm + MBX) static DTLB
entries are used, which are loaded at BSP initialization (mmu_init()),
and then left alone.
As all network buffers (cbuf and cclusters) are funneled through a common
routine in the BSD stack, it is possible to modify the allocation to
get memory from a uncachable region, once you manage to set it up and tell
the MMU about that. A problem to solve is the page size, you will have to
go to 512k instead of 8M, and that wastes a lot of DTLB entries.
Please note, that you probably will have to modify other device drivers as
well.
gm
