Network config issue
Chris Johns
cjohns at cybertec.com.au
Mon Sep 25 22:52:20 UTC 2000
Joel Sherrill wrote:
> What about a 2nd interface so a router type setup is very simple? This
> might (unfortunately) requires duplicate entries with names like
> "CONFIGURE_RTEMS_NETWORKING_USE_BOOTP_SECOND_IFACE" or some such.
Can confdefs.h have an include to handle the network configuration ?
> ALso if you say "don't use Bootp", then what should happen if you
> don't set things like host name, domain name, gateway, etc.
I found the BSD stack needs some files setup for certain configurations.
If a filesystem exists maybe they should also be created with basic
default values, eg localhost.
Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
