Getting Started ( hello_wrorld_c trouble )
gerke.kok at tpa-nl.com gerke.kok at tpa-nl.com
Fri Sep 29 06:58:19 UTC 2000
Thanks a lot!
wkr,
Gerke
-----Oorspronkelijk bericht-----
Van: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Verzonden: Thursday, September 28, 2000 20:36
Aan: Chang Lyong Kim
CC: rtems-users at OARcorp.com
Onderwerp: Re: Getting Started ( hello_wrorld_c trouble )
Known problem in hello world.  Fixed in the attached file.
Chang Lyong Kim wrote:
> Dear,
> I am trying to install RTEMS for C/C++ on RedHat6.2 Linux PC.
> I found these things and installed very quickly.
> m68k-rtems-binutils-2.9.5.0.24-1.i386.rpm
> m68k-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
> m68k-rtems-gdb-4.18-4.i386.rpm
> rtems-base-binutils-2.9.5.0.24-1.i386.rpm
> rtems-base-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
> rtems-base-gdb-4.18-4.i386.rpm
> Then, I followed RTEMS installation procedure from "Getting Started..."
> configure --target=m68k-rtems --prefix=/usr/local/cross
> make RTEMS_BSP="gen68360"
> make install  RTEMS_BSP="gen68360"
> No problem here.
> Then, when I tried to compile test.c under hello_world_c.tgz,
> I got the following error.
> /opt/rtems/bin/m68k-rtems-gcc --pipe -B/usr/local/cross//gen68360/lib/
> -specs bsp_specs -qrtems -g -Wall -ansi -fasm  -O4 -fomit-frame-pointer
> -mcpu32     -c   -o o-optimize/test.o test.c
> In file included from test.c:28:
> /usr/local/cross/gen68360/lib/include/confdefs.h:1005: #error
> "CONFIGURATION ERROR: No tasks or threads configured!!
> #endif
>  *  Make sure at least one of the initialization task/thread
>  *  tables was defined.
> #if !defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE) &&
> !defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) &&
> !defined(CONFIGURE_ITRON_INIT_TASK_TABLE)
> #error "CONFIGURATION ERROR: No initialization tasks or threads
> configured!!
> make: *** [o-optimize/test.o] Error 1
> When I removed
> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_INIT
> #include <confdefs.h>
> from test.c,
> it produced,
> -mcpu32      -L /usr/local/cross//gen68360/lib    -o o-optimize/test.exe
> o-optimize/test.o   /usr/local/cross//gen68360/lib/no-dpmem.rel
> /usr/local/cross//gen68360/lib/no-event.rel
> /usr/local/cross//gen68360/lib/no-msg.rel
> /usr/local/cross//gen68360/lib/no-mp.rel
> /usr/local/cross//gen68360/lib/no-part.rel
> /usr/local/cross//gen68360/lib/no-signal.rel
> /usr/local/cross//gen68360/lib/no-timer.rel
> /usr/local/cross//gen68360/lib/no-rtmon.rel
> /usr/local/cross//gen68360/lib/librtemsall.a(bootcard.o): In function
> `boot_card':
/home/clkim/rtems/tools/rtems_build/m68k-rtems/c/gen68360/lib/libbsp/m68k/ge
n68360/startup/../../../../../../../../../rtems-4.5.0-beta3a/c/src/lib/libbs
p/m68k/gen68360/startup/../../../shared/bootcard.c:93: undefined
> reference to `Configuration'
> ..........BlaBla...
> Any comment is welcome!!!
> Thank you very much,
> Chang
