TEXT section in RAM - how?
Sturniolo Jose
jsturnio at nec.com.ar
Wed Apr 4 20:03:34 UTC 2001
Hi Ilya,
I have a linkcmds and c code that allow to do the following:
- De-compresion of Text and Data area, after the first DRAM, SRAM registers
configuration
- No Copy of Text,Data area, because the de-compresor work from ROM to RAM
directly.
- The compression method is GZIP (the code was borrowed from LINUX kernel)
This method was used because I need a large ROM capacity. It has a "negative
effect", that is the neccesary time to decompress the kernel, about 15
seconds (with a 25MHZ processor) in each boot.
Tell me if you are interested in it, and I'll send you the code.
Regards, José.
-----Original Message-----
Sent: Miércoles, 04 de Abril de 2001 08:52 p.m.
To: rtems-users at OARcorp.com
Subject: TEXT section in RAM - how?
Hi all.
To gen68360 users:
Does anyone have a system which copies from ROM to RAM not only the .DATA
but the .TEXT section too?
How should I modify linkcmds and start.S for this?
Best regards,
Ilya mailto:ilya at continuum.ru
