Decompression code
Sturniolo Jose
jsturnio at nec.com.ar
Mon Apr 9 19:16:44 UTC 2001
Ilya,
Here I'm including a zip file with the files changed to get a
"COMPRESSED" image file.
I'll try to explain how it works, in order to clarify the code:
LINKCMDS:
Basic regions map.
ROM image mapping:
.textrom
First configuration code (BSP, start) and decompresor (@miscgz.o)
Compresed File containing .text, .data, generated by apl / Makefile
using gzip.
.text
All the uncompresed code.
Contains all the code EXCEPT : start.o, init68360.o and @miscgz.o (I
tried to use the EXCEPT keyword at link time, but I got it working when I
was finished with it)
.data
All the uncompresed data
.datarom
Data segment used to hold variables used by the decompresor.
The basic idea is:
The loader code must to be set into in the .textrom and .datarom segment,
by mean of keywords like :
void _Init68360 (void) __attribute__((section(".textrom")));
You can avoid to used these keywords if you use the EXCEPT keyword in the
linker, but this keyword must be used with a entire object file.
Main changes related to original file:
start.S => section is .textrom now. ClearBSSandStart function was added.
init68360 => section is .textrom now. After the first settings, the
decompresion function is called (decompress_kernel() )
@miscgz => new file, contains the decompresion code.
apl / Makefile => you can use this example makefile to build the compressed
image, it use the gettdb.pl file.
Regards.
<<tests.zip>>
Jose Sturniolo
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010409/0fc9a3a5/attachment.obj>
