ICD_BDM and problems with stepping through some instructions
Benshoof, William {17-7~Roswell} WILLIAM.BENSHOOF at ROCHE.COM
Tue Apr 10 17:25:28 UTC 2001
Hello,
I am using a Motorola 68332ACFC16 with GDB 4.18, BDM patches for Linux,
ICD_BDM driver, and PE Micro debugger.  I have a problem stepping through
some instructions (MOVEL is one) that I wonder if anyone else has
encountered.  The error is bdm_signal_handler: failed to stop chip no
response from target via bdm.  The work-around is to set a breakpoint after
the offending instruction and "continue" to it.
>From reading past user group messages and Pavel Pisa's 6/30/99 document, I
think this might have something to do with internal GDB timing.
Has anyone else seen this problem?  Found a solution?  Have hints on where
to look?
Bill
URL: <http://lists.rtems.org/pipermail/users/attachments/20010410/141bc432/attachment.html>
