Does powerpc build/work in 4.5.0?
Nick.SIMON at syntegra.com Nick.SIMON at syntegra.com
Wed Apr 18 17:33:02 UTC 2001
We are using 4.5.0 beta 3a - which was the last beta before the "official"
4.5.0 - on our proprietary mpc860 card, with a BSP derived from eth_comm
(but with no canbus).  Build environment is Red Hat 6.2 Intel.  It all
builds and works OK.  You most certainly do need a set of cross-building
tools but these are now available as RPMs for red hat + intel (& others),
which avoids a lot of the grief we had in the "old days".
I am most suprised 4.5.0 doesn't build for you, and I bet Joel is too!
Don't give up, but do post your error output.
Regards,
-- Nick Simon
> -----Original Message-----
> From: Tom Armistead [mailto:tarmiste at phx.mcd.mot.com]
> Sent: 18 April 2001 18:16
> To: rtems-users at oarcorp.com
> Subject: Does powerpc build/work in 4.5.0?
> Hi,
>    I'm a newbie here so pardon if this is a dumb newbie question(s)...
>    I'm interested in using 4.5.0 on powerpc boards.  At this
> point, I'm
> not even able to get it to compile though.  One of the problems I've
> found is in lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (and .in).
> It has 'anclude' instead of 'include'.  And other
> miscellaneous hiccups
> occur during the build as well.
>    The release notes indicated that the powerpc should at least build
> but I don't know how it possibly could with the above kind of thing in
> it.  Has anyone successfully built the powerpc portions of
> 4.5.0 and if
> so, can you point me in the right direction?
>    I've tried doing a native build on both LinuxPPC2000 and Debian 2.2
> PPC machines.  I've also tried doing a cross compile build on an intel
> redhat system.  Is there a specific build environment that is required
> for building powerpc?  (I was able to do a build for intel and run the
> resulting images using the same redhat system).
>    I like RTEMs a lot; it has all the basic building blocks I need for
> my application and I'm willing to spend some time to get it working on
> powerpc but I don't know how much effort it will need or where even to
> begin.  Or whether it already works and I just am doing
> something wrong.
> Tom Armistead
Check us out at http://www.syntegra.com
