Thu Apr 26 16:34:00 UTC 2001
"Hargenrader, Louis A." wrote:
> I'm  trying to get the POWERPC port up and running. So far after struggling
> through with some file directory rearrangements I have been able to get
> RTEMS 4.0 to build but when I compile the TESTS for the PSIM BSP just to
> check out the install I get a linker error that in the module "makebuf.c 93
> " which is part of libc.a there is an undefined ref "isatty".  I'm using the
> prebuilt compliler tools for cygwin from the OARCorp site.  Do I need a
> different version of NEWLIB?
The pre-compiled versions of the tools are intended to be used with
RTEMS 4.5.0.
> LOUIS A HARGENRADER
> Northrup Grumman Corp.
