Possible HDTV Project
Fri Apr 27 01:23:08 UTC 2001
Charles Nelson wrote:
> Hi,
> I am actively working on a PCI based HDTV design using the Equator MAP-CA.
> This design will migrate to a HPNA enabled "Streaming Media Thin Client" and
> I will probably use RTEMS as the OS for that project.  Will I have any
> problems using RTEMS in a commercial product?
There are many ways to interpret this question:
  + licensing  - no problem.  The RTEMS license permits this.
  + support - no problem.  That's what OAR provides.
  + training - ditto
  + customization - ditto plus others can help.
  + technical - depends on what you are using but generally no.
    There are some non-kernel add-ons that are technically under
    development but RTEMS provides stable and compatable
    POSIX and pSOS+-like APIs plus a port of the FreeBSD TCP/IP
    stack.  Porting code is generally no problem.
Ask more specific questions if you want to know about performance
of feature X on CPU Y. :)
> Charles L. Nelson
> Embedded Systems Architect
> Lumenati, Inc.
> 2591 Kerner Blvd.
> San Rafael, Ca. 94901-9800
> Web
> - www.lumenati.com <http://www.lumenati.com>
> Toll Free
> - (866) 586-3628
> Main
> - (415) 455-9500
> Fax
> - (415) 259-2828
> Direct
> - (415) 455-9500 x 1150
> Mobile
> (415) 577-6496
> Email
> - cnelson at lumenati.com
> The Lawyers Made Me Say This:
> The information contained in this electronic message (email) is confidential
> and intended only for the use of the individual or entity named above.  If
> the reader of this message is not the intended recipient, you are hereby
> notified that any dissemination, distribution, or copy of this communication
> is strictly prohibited.  If you have received this communication in error,
> please notify us immediately by telephone at (800) 440-6388 or by email.
