mvme2306
D. Peter Siddons siddons at bnl.gov
Sun Apr 29 20:30:33 UTC 2001
Hi Eric,
    Thanks very much for pointing out the info in the various README's.
I know, always rtfm! Oh well. Anyway, with that and
a pointer from Joel Sherrill about modifying the mvme2307.cfg file,
I got a boot image and was able to load it. Here's what happened for
the 'paranoia' sample:
  Network Boot File load in progress... To abort hit
<BREAK>
  Bytes Received =&155352, Bytes Loaded
=&155352
  Bytes/Second   =&77676, Elapsed Time =2
Second(s)
  Residual-Data Located at:
$01F88000
  Model:
000000000000000000000000000(e2)
  Serial:
MOT041EDE2
  Processor/Bus frequencies (Hz):
333371008/66674344
  Time Base Divisor:
4000
  Memory Size:
2000000
  Original MSR:
3040
  Original HID0:
82
  Original R31: 0
  PCI: Probing PCI
hardware
  RTEMS 4.x/PPC
load:
  Uncompressing the
kernel...
  Kernel at 0x00000000,
size=0x3b000
  Initrd at 0x00000000,
size=0x0
  Residual data at
0x0003b000
  Command line at
0x00042000
done
  Now
booting...
and then nothing. THe processor activity light goes out and it just
hangs. I have tried using the PCI and VME chip configurations given
in the README's, and also the suggested configuration from the Motorola
manual for a PREP setup. It gives the same result. Am I doing something
wrong?
Pete Siddons.
Eric Valette wrote:
> "D. Peter Siddons" wrote:
> > Hi,
> >    I'm trying to set up RTEMS for this ppc-based vme card, mvme2306.
> > It is identical to the supported mvme2307 except it has less RAM.
> > RTEMS builds without problems, but I don't know how to boot the
> > resulting .exe file (e.g. hello.exe). I have PPCbug set up to
> > download the file using tftp, and that works OK, but simply loading
> > the .exe fails with an illegal instruction. Do I need to reformat the
> > file somehow? Sorry for the (probably)trivial question, but I am just
> > getting started.....
> > Pete Siddons.
> Read the various *readme* in the BSP directory. Everything is explained
> there (how to congigure PPCBUG for network boot and Prep compliance).
>    __
>   /  `                          Eric Valette - Canon CRF
>  /--   __  o _.                 Canon Development Europe Team Leader
> (___, / (_(_(__                 Rue de la touche lambert
>                                 35517 Cesson-Sevigne  Cedex
>                                 FRANCE
> Tel: +33 (0)2 99 87 68 91       Fax: +33 (0)2 99 84 11 30
> E-mail: valette at crf.canon.fr    http://www.crf.canon.fr
