TEXT section in RAM - how?
Sturniolo Jose jsturnio at nec.com.ar
Thu Apr 5 12:59:10 UTC 2001
Hi Craig, thanks by your appointment. I'll try it.
Regards, José.
-----Original Message-----
From: Craig Graham [mailto:craig at data-uncertain.co.uk]
Sent: Jueves, 05 de Abril de 2001 07:38 a.m.
To: Sturniolo Jose; rtems-users at oarcorp.com
Subject: Re: TEXT section in RAM - how?
On Wednesday 04 April 2001 21:03, Sturniolo Jose wrote:
> Hi Ilya,
> 	I have a linkcmds and c code that allow to do the following:
> - De-compresion of Text and Data area, after the first DRAM, SRAM
registers
> configuration
> - No Copy of Text,Data area, because the de-compresor work from ROM to RAM
> directly.
> - The compression method is GZIP (the code was borrowed from LINUX kernel)
> This method was used because I need a large ROM capacity. It has a
> "negative effect", that is the neccesary time to decompress the kernel,
> about 15 seconds (with a 25MHZ processor) in each boot.
Depending on your system architecture, you might find that it's actually
quicker to copy the gzipped image to DRAM before you unpack it - we found
this using a gzip'ed boot loader on our own system - copying the gzip'ed
image to RAM before unpacking was around 3x faster than unpacking direct
from
the ROM's.
I'm thinking it's 'coz gzip will do multiple single byte reads from the ROM
worst case you have approx N accesses to the ROM for an N byte file ,
whereas
doing a full word width copy from ROM to RAM does the minimum number of
accesses (N/4 for an N byte file on a 32bit CPU with 32bit ROM's).
> Regards, José.
Craig.
