68360 BDM and P&E
OUTWATER ~ KEITH J /5G3110
vac4050 at tueng.rsc.raytheon.com
Tue Apr 10 23:56:54 UTC 2001
The P&E interface works fine with gdb-bdm. I've used gdb-bdm-2000902 with good
results. The driver in gdb-bdm you want to use is the 'ICD' driver.
Keith
Keith Outwater
Principal Engineer
Raytheon Missile Systems
Tucson, AZ
(520) 794-2518
vac4050 at cae597.rsc.raytheon.com
> Hello,
> I've been using the public domain BDM interface for a 5.0 volt
> 68360 system, but recently designed a board for the 3.3 volt
> version. I ordered the P&E Micro 3.3 volt compatible BDM adapter,
> but can't figure out what version of the GDB BDM stuff I need.
> Does the GDB BDM support the P&E Micro cable for 68360 systems or
> just ColdFire systems?
> Jake
