Newbie question
Tue Apr 24 20:59:32 UTC 2001
Camilo Alejandro Arboleda wrote:
> Hello!
> 1. I installed rtems 4.5.0 under Debian. It works fine, but I had not
> been able to create no-debugging versions of the binaries. The compiler
> creates o-optimize version, but they have debugging information. I
> supose it is related to the rtems VARIANT  option, but I´m not sure. If
> someone can explain or tell me where to get information about, thanks.
Did you use "make VARIANT=DEBUG"?
> 2. Is it possible to have more than one version of rtems installed
> (i386, mc68k and posix at the same time).
Yes. :)
With 4.5.0, I recommend using /opt/rtems/CPU-rtems as the prefix when
building RTEMS.  This collects BSPs per CPU family and is the default
in the development source.
> Thanks,
> Camilo Alejandro Arboleda.
