file i/o troubles
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 24 21:36:17 UTC 2001
Andrew Bythell wrote:
> Hi -
> Attached is a sample application that demonstrates the problem.
Ahhh.... test cases. :)
This was an interesting artifact of the file descriptors
not being completely reinitialized. The fix was 1 line
to memfile_open to set the file size field in the
libio structure. I also took the liberty to modify
rtems_libio_allocate() to clear out offset and size
to remove the now redundant iop->offset=0 from open().
The tftp and any other filesystems need to be updated to
set the file size in their open handler. I do not know
how to do this for tftp.
Thanks for the bug report. It took a nice example to test it.
--joel
> Andrew.
> jennifer averett wrote:
> > Do you have a complete test that shows this problem that you
> > could submit? It is much easer to reproduce and
> > fix problems that way.
> > Thanks
> > Jennifer
> > > Hello -
> > > I am seeing strange behaviour when writing to files using the IMFS and
> > > rtems-ss-20010326. I had this same problem with earlier snapshots too.
> > > Consider:
> > > FILE *fp = fopen("somefile", "w");
> > > fprintf(fp, "line1\n");
> > > fclose();
> > > fp = fopen("somefile", "a");
> > > fprintf("fp, "line2\n");
> > > fclose();
> > > The first time I call this routine, 'somefile' is created and contains:
> > > line1
> > > line2
> > > which is fine. Subsequent calls, using the same or different filename,
> > > insert junk (NULL characters) between line1 and line2:
> > > line1
> > > line2
> > > Can anyone offer an explanation and/or solution?
> > > Andrew Bythell
> > > Nortel Networks System Verification
> > > Ottawa, Ontario Canada esn.39.56930
> > > tel.613.765-6930 fax.613.763-7795
> ftest.tar.gz Type: GNU Zip (application/x-gzip)
> Encoding: base64
joel at OARcorp.com On-Line Applications Research
Index: c/src/lib/libc/libio.c
RCS file: /usr1/CVS/rtems/c/src/lib/libc/libio.c,v
retrieving revision 1.35
diff -u -r1.35 libio.c
--- c/src/lib/libc/libio.c 2001/01/08 18:26:44 1.35
+++ c/src/lib/libc/libio.c 2001/04/24 21:50:11
@@ -208,6 +208,8 @@
rtems_libio_iop_freelist = iop->data1;
iop->data1 = 0;
iop->flags = LIBIO_FLAGS_OPEN;
+ iop->size = 0;
+ iop->offset = 0;
goto done;
Index: c/src/lib/libc/open.c
RCS file: /usr1/CVS/rtems/c/src/lib/libc/open.c,v
retrieving revision 1.9
diff -u -r1.9 open.c
--- c/src/lib/libc/open.c 2001/01/08 18:26:44 1.9
+++ c/src/lib/libc/open.c 2001/04/24 21:50:11
@@ -146,7 +146,6 @@
* returned by successful path evaluation.
- iop->offset = 0;
iop->handlers = loc.handlers;
iop->file_info = loc.node_access;
iop->flags |= rtems_libio_fcntl_flags( flags );
Index: c/src/libfs/src/imfs/memfile.c
RCS file: /usr1/CVS/rtems/c/src/libfs/src/imfs/memfile.c,v
retrieving revision 1.14
diff -u -r1.14 memfile.c
--- c/src/libfs/src/imfs/memfile.c 2001/03/23 14:02:02 1.14
+++ c/src/libfs/src/imfs/memfile.c 2001/04/24 21:50:22
@@ -98,6 +98,7 @@
if (iop->flags & LIBIO_FLAGS_APPEND)
iop->offset = the_jnode->info.file.size;
+ iop->size = the_jnode->info.file.size;
return 0;
